Home Forums Product Discussion & Questions BeoMaster need your advice with beomaster 4000 repair
  • #73090
    vladK
    I need some advice regarding repair of a Beomaster 4000 (2406).
    It came to me as a botched repair with right channel darlingnon transistors burned out (TR43/46/47). TR44/45/41/42 were also burned out. I replaced many out of spec resistors and all electrolytic capacitors.
    I started testing with output darlingtons disconnected to ensure all voltages are correct. The left channel would balance out with correct voltages, but the right channel would not – the TR43 would stay on VCC (70V), instead of about half that value.
    I noticed that the replacement TR44 (BC114) does not conduct during the power up sequence – the Vbe is about 0.3V at all times. TR41/42 never get to conduct, which in turn never sets correct base voltage for TR43.
    I then swapped TR44/45 pair with TR55/56 (left channel) to ensure that the replaced components and board work in the right channel is correct.  Sure enough – the voltages on the right channel are now measuring correct, but the left channel now has the same problem.
    This lead me to a conclusion that the difference is in BC114 and BC252B pair between two sides. Using a transistor tester I tested all four transistors. The BC114 on the side that works tests with a very low Vbe forward voltage (0.2V) compared to the replacement BC114 I purchased (0.66V). This does not make sense since the BC114 specification sheet shows Vbe of 0.64-7.0V for both.
    My question for you is: is there anything special about BC114 transistor used in Beomaster 4000?
    I see that service manual shows two revisions of the bias circuit for these two transistors. Is it worth implementing these revisions to fix this problem?
    I must say I am a bit perplexed by the complexity Beomaster 4000 feedback loop and the fact that BC114 the working channel does not measure as specified.
    Thank you for your help.
    Vlad
    • This topic was modified 4 days, 5 hours ago by vladK.
    • This topic was modified 4 days, 3 hours ago by vladK.
    • This topic was modified 3 days, 23 hours ago by vladK.
    Favourite Product: Beomaster
    #73327
    vladK
    Can someone with Beomaster 4000 (2406) help me get some traction on this problem?
