Home › Forums › Product Discussion & Questions › BeoGram › Need help sourcing a BEOGRAM CD 50 laser
- This topic has 8 replies, 4 voices, and was last updated 3 years, 8 months ago by
chartz.
28 June 2022 at 01:13 #35797
Cavscout
BRONZE MemberHi
I am looking for a laser for a CD 50 but nothing comes up on google.
Does anyone know where I can find one ?
Here is a video of the problem I am facing:
28 June 2022 at 15:16 #35798 chartz
BRONZE MemberYou can’t. But are you certain that the laser is toast? Very unlikely.
The laser head should be near the centre – its normal parking position – and the end position switch engaged.
Investigate this. Try to manually slide the laser sled towards centre (done that?, it isn’t clear) and see what happens.
2 July 2022 at 16:02 #35799solderon29
GOLD MemberAgreed!
These (Sony) lasers are very long lived usually.What symptoms do you have with the unit?
It should automatically drive the sled to the centre after the disc loads,so that the disc can be read.If that does’nt happen,it may be taking too long to load,which could be due to a loose/worn mechanism drive belt(common problem)Also the loading mechanism is probably slow due to dried out grease etc.The computer will block if the loading takes too long.It senses via microswitches attached to the mechanism.These become tarnished with age.
Great machines,worth persevering with.
Nick
3 July 2022 at 14:30 #35800 chartz
BRONZE MemberYes, great machine with a mellow sound, really nice. ??
3 July 2022 at 19:42 #35801Dillen
ModeratorWhen you press play, Beogram CD50 will:
Move tray in.
Check for presence of disc.
If disc is present, lift disc to engage with motor spindle hub.
Run trackingmotor to make the laser carriage reach the track 0 switch.
When track 0 switch is reached, start disc motor.
When disc motor is running, switch on laser and read TOC.
Etc…Your deck stops at moving the carriage.
It seems the carriage is all the way out – it should move all the way in. (CD’s play from inner tracks out).You tell that you have taken it all apart and put back togehter. Are you sure you got the tracking motor polarity right?
(For reasons unknown to me no longer Dillen)4 July 2022 at 00:22 #35802Cavscout
BRONZE MemberSo I have tried some thing and was able to figure out why there was no spinning motor or movement of the sled.
It turns out that there was a 3 prong switch not engaging so the CD player would never actually realize it was CLOSED.
So I fixed that but it still won’t spin the discs 🙁
Please see the video I made:
I really appreciate this help , thank you
5 July 2022 at 05:59 #35803 chartz
BRONZE MemberHi,
It sounds as if something is rubbing. The rotation should be silent. Are you certain that the disc is properly clamped?
6 July 2022 at 13:18 #35804Cavscout
BRONZE MemberI am not sure if it is clamped properly.
That is a challenge. With the drawer closed it is not possible to see if it is clamping.
It seems like it is though.
But is that motor supposed to spin like that ?
8 July 2022 at 06:00 #35805 chartz
BRONZE MemberThe rattle is not normal. Just feel if the CD is clamped completely. When it starts turning, unplug the player and feel whether the CD has some play as regards to its platter.
