Home › Forums › General Discussion & Questions › General Discussion & Questions › Need assistance: Beo Terminal 7000
- This topic has 5 replies, 3 voices, and was last updated 2 years, 7 months ago by
chartz.
9 August 2023 at 02:42 #48146
Sy BenBRONZE MemberI’m looking for the BEO Terminal but I’m not sure if the 7000 version supports BEOMASTER 6000 or not. Can someone help me with this.
Favourite Product: Beomaster 8000
9 August 2023 at 07:02 #48147Dillen
ModeratorBeolink 7000 does not operate Beomaster 6000.
You will need the Terminal 6000.https://www.beoworld.org/prod_details.asp?pid=994
9 August 2023 at 17:18 #48148 chartzBRONZE MemberHi,
Or the Terminal 8000, of course. But no stepped volume drops or reset! But it does work fine.
Jacques
12 August 2023 at 08:11 #48149 Sy BenBRONZE MemberBeolink 7000 does not operate Beomaster 6000. You will need the Terminal 6000. https://www.beoworld.org/prod_details.asp?pid=994 Martin
Thank you, I think I will look for the Terminal 6000 for synchronization 🙂
12 August 2023 at 08:13 #48150 Sy BenBRONZE MemberHi, Or the Terminal 8000, of course. But no stepped volume drops or reset! But it does work fine.
Jacques
Thank you, I have a slightly off-topic question. My device operates on 120V power, is there any way to switch it to 220V by changing the power transformer?
12 August 2023 at 18:50 #48151 chartzBRONZE MemberOf course, if you can find one.
