Home › Forums › Product Discussion & Questions › BeoSound › Theatre › Moving a Theatre + 65″ LG
- This topic has 1 reply, 2 voices, and was last updated 2 years, 6 months ago by
Severed_hand_of_skywalker.
8 September 2023 at 03:42 #48813
etype76
BRONZE MemberHi all,
I’m having a new TV cabinet delivered tomorrow. I’m a bit concerned about the Theatre connected to the LG with the B&O mount. I’ve explained the setup to the furniture store but as you’d imagine, they’re not installers. I just want them to carefully move the whole thing off the old cabinet onto a low table and then move it back onto the new cabinet. I’ll disconnect everything etc. Is there anything I should be aware of? Any tips beyond prayer will be encouraging.
Thx
8 September 2023 at 06:38 #48814 Severed_hand_of_skywalkerBRONZE MemberI would do it yourself with help from them or a friend.
