Home › Forums › Product Discussion & Questions › BeoCenter › Modern speakers for Beocenter 2200?
- This topic has 3 replies, 2 voices, and was last updated 3 years, 1 month ago by
Mark-sf.
26 February 2023 at 07:20 #44152
hmm
BRONZE MemberHope someone can suggest something…
I’m about to dig out my old Beocenter 2200 (not used for the past 20+ years).
I’d like to connect some speakers that are perhaps slimmer or more stylish than the originals (Beovox 25?).
I don’t know the technical requirements but they don’t need to be more powerful than the originals.
Any suggestions anyone? Many thanks.
27 February 2023 at 03:31 #44153 Mark-sf
BRONZE MemberBy slim do you mean less wide or less deep? If you want to preserve it as a B&O system, a pair of CX100’s are narrower and are quite stylish IMHO. Remember, this unit has a built-in loudness contour in the volume control (which you can’t bypass without getting inside) so should not be paired with speakers that are bass heavy.
1 March 2023 at 22:22 #44154hmm
BRONZE MemberMany thanks Mark.
Just wondering – CX100s are 6 ohm, 2200 is 8 ohm; does this have any effect in practical terms?
1 March 2023 at 23:45 #44155 Mark-sf
BRONZE MemberNo, as the amp is rated at 25W into 4 ohms.
