Home › Forums › Product Discussion & Questions › BeoGram › MMC 6000 Setting Question
- This topic has 2 replies, 2 voices, and was last updated 5 months, 2 weeks ago by
hunchbacker.
15 October 2025 at 23:59 #70498
hunchbacker
BRONZE MemberCurrently have my 4002 up and running again after a much needed damper lubrication and pivot arm cleaning. My receiver has both MM and MC settings. I’ve noticed the output is lower than my other turntables when on the MM setting. When switched to MC it seems much louder and fuller. I am aware it is often recommended to use the MM setting. Any thoughts on this?
16 October 2025 at 17:38 #70510 Mark-sfBRONZE MemberThe proper setting is MM. it does have lower output than typical.
17 October 2025 at 13:38 #70528hunchbacker
BRONZE Memberthanks pretty much confirms what I have found.
