Home › Forums › General Discussion & Questions › General Discussion & Questions › ml powerbox alternative
- This topic has 31 replies, 3 voices, and was last updated 1 year, 11 months ago by
Madskp.
13 April 2024 at 09:19 #54128
Madskp
GOLD MemberI can try to test it if I can find the time later this weekend
13 April 2024 at 09:45 #54129 Tignum
GOLD MemberThat is very kind! Regards, Johan
13 April 2024 at 10:27 #54130Madskp
GOLD MemberInteresting. Roughly what I expected to be in there. The 5-pin chip is an unregulated charge pump used for inverting the + 5V from USB to -5V. The smaller ones on the other side of the board are indeed some diodes and two resistors. They are used for providing power to the data lines.
Ok so if I understand correctly the ML power box only deliver the 0.25/-0.25V for the datalines and not the higher voltages on the pink and blue wires?What could be the reason for not having the supply of the data voltages in the BLC NL/ML? Is it because there can only be one unit providing it in a ML network?Location: Denmark
13 April 2024 at 12:02 #54131B3OHACK3R
BRONZE MemberOk so if I understand correctly the ML power box only deliver the 0.25/-0.25V for the datalines and not the higher voltages on the pink and blue wires?
Yes, it provides the termination voltages for the datalines and 5V to the ML Power + pin. Probably ML Power – is also supplied with -5V but I don’t think any of the common ML devices uses that. As I said earlier everything will communicate just fine if you provide it with the data termination voltage and 5V on the pink + blue/white cable.
I have never looked into a BLC and there is no public schematic available. I don’t know if it is using the old ML ASIC or a discrete solution. In any case I put my bets on a hardware design issue. They either may have just forget about that feature during development or initially it was never planned for the BLC to become a master. Who knows…
Technically you could get away with multiple “Power Master” if they have at least some reverse current protection. Maybe two or three would still work okay but the cleanest way is of course only having one.
13 April 2024 at 12:33 #54132Madskp
GOLD MemberOk so if I understand correctly the ML power box only deliver the 0.25/-0.25V for the datalines and not the higher voltages on the pink and blue wires?
Thanks for these answers. Helps a lot understanding how a ML system works.
13 April 2024 at 12:35 #54133Madskp
I have tried now, and the Beolink passive provides 0V on both power and data lines when not connected to other ML equipment
13 April 2024 at 13:47 #54134 Tignum
GOLD MemberThanks Madskp – ML Power box still part of the factory planning :-). Regards, J.
14 April 2024 at 20:22 #54135Madskp
GOLD MemberOne thing that just came to me if you have the Beolink passive in mind. If it makes sense could you use the BLC with an IR eye as the linkroom and the the passive connected via powerlink to drive passive speakers?
The powerlink cable has to be fully wire for this to work
15 April 2024 at 07:17 #54136 Tignum
GOLD MemberHello Madskp, that is a good hint, did not think of that option yet. And to be complete, even the fully wired PowerLink cable might not be enough to get it working 🙂 https://forum.beoworld.org/forums/topic/beoplay-connection-hub-beolink-passive/
My latest plan is to use a BLC (I do have a ‘JOIN’ IR eye already) and two BL7-4s (that I now have as well). I will see to feed the L/R speakers with Left and Right signals only. I took the BL2000 to the garage for a ‘fit’ and I fear it will be a bit small in the 3x6m space. And now I have a purpose for those 7-4s!
The BL2000 will move to the garden I reckon (cabled).
Thanks, Johan
15 April 2024 at 08:19 #54137Madskp
GOLD MemberAnd to be complete, even the fully wired PowerLink cable might not be enough to get it working ? https://forum.beoworld.org/forums/topic/beoplay-connection-hub-beolink-passive/
Yes that’s right. This might also be an issue with the BLC
Talking about an upgrade 🙂 But this will avoid those extra boxes for sure (unless you count the 7-4s as boxes).
Or you could get an extra BLC now that you have the powerbox 😉
2 May 2024 at 07:23 #32763 Tignum
GOLD MemberHi Madskp, I think one or two posts got lost :-). Good plan and minimum of boxes! I now have one compatible IR eye, two freshly powdercoated BL7-4s and will get a BLC on Saturday. In my garage project I will make sure that I feed the 7-4s only with L and R signals respectively. I will do so in a double RJ45 wall outlet, keeping one socket fully wired, and one L or R.
Regards, Johan
2 May 2024 at 07:42 #32766Madskp
GOLD MemberYou are right. I remember you allready had a post about the 7-4’s. But great plan to keep it simple and now you have the ML powerbox for other stuff.
And if nothing else we learned a little about the “magic” going on in the ML powerbox
