Home › Forums › Product Discussion & Questions › Other › Midrange speakers on my Penta – If one speaker is dead do they all not work?
- This topic has 3 replies, 3 voices, and was last updated 2 years, 3 months ago by
Raiderxx.
21 December 2023 at 09:22 #51455
Raiderxx
BRONZE MemberFollowup to this post. So I got the cap kit, and replaced everything required (boy were the crossovers easier than the amp!!). The bass significantly was improved in quality. However the mid speakers remained unchanged.. not working. I removed the mid/tweeter speaker assembly and replaced with the same assembly from the other Penta. BOOM! Worked great! That leaves the problem residing in the speakers themselves.
Got out my multimeter, and checked continuity. 3 speakers were good, the last one, no continuity…..
Now this is where the newbie in me goes “OOOOOH DUH”: I should have checked the speakers first, before refoaming them………. I’m nearly in tears that I’m going to have to spend $50 to replace the speaker but also purchase and refoam the NEW speaker presumably..
So my question is, could this bad speaker be the reason NONE of the mids work? It is the speaker connected to the green wire that is dead. By my reading of the schematic, I would have thought at least the two outside speakers in the assembly (the one attached to the blue wire and the bottom) would potentially work still..
I’ve already put (I refuse to use the word “sunk”) around $200 into these Pentas, between purchasing them, the foam, and the amp/crossover kit. I understand that is an incredibly good deal, even for where I am, I just want to make sure I’m on the right path.. I assume bridging and bypassing the dead speaker would damage the other 3.. Any guidance would be appreciated!
22 December 2023 at 12:10 #51456Dillen
ModeratorAn open-circuit midrange will see all four going silent.
I have one, refoamed and ready.
PM me if you need.Martin
27 December 2023 at 13:21 #51457Binny
BRONZE MemberHi
one of my penta speakers has now got a orange light at the bottom. Even when using the power switch if moved to off – it’s still orange.
the other speaker is fine and working
ive checked the wires and all look ok. Any ideas?
27 December 2023 at 18:32 #51458Raiderxx
BRONZE MemberI had a similar situation, if you unplug the amp and plug it back in does it go green (when you have it on) for a few seconds? What I read was orange means there’s a problem with the amp. Getting the cap kit seems to have fixed the problem as I have not had the orange ligjt since I replaced the capacitors.
