Home › Forums › General Discussion & Questions › General Discussion & Questions › MCL2P crackles and fades out
- This topic has 2 replies, 2 voices, and was last updated 3 years, 9 months ago by
coolhandxxx.
10 May 2022 at 12:57 #34735
peppsModeratorHello everyone,
I recently bought a MCL2P from eBay in order to enjoy my Beosystem 2500 through a pair of Beovox 3000 (flat panel) passive speakers.
On connecting (with a nice new powerlink cable from Steve @ Sounds Heavenly) the MCL2P would switch on with 2 reassuringly B&O clicks and music would flow.However, after 24 seconds (consistently so) the speakers would make a crackling sound and the music would fade away to nothing.
The reset button on the front face has no effect.
Only disconnecting from the mains will reset this cycle. And again, only 24 seconds of music before I hear crackle and fade to nothing.
On insoection, the main PCB looks to be ok. I have freshened up only a few solder joins which were looking dull.
on testing this has had no affect on the issue.Should I take out the power coils and have a look around them too?
Has anyone else had similar problems with MCL2P units?
I’d love to get this one going.Many thanks,
Julian
Favourite Product: Beosystem 6500
30 May 2022 at 15:32 #34736 peppsModeratorHello everyone, I recently bought a MCL2P from eBay in order to enjoy my Beosystem 2500 through a pair of Beovox 3000 (flat panel) passive speakers. On connecting (with a nice new powerlink cable from Steve @ Sounds Heavenly) the MCL2P would switch on with 2 reassuringly B&O clicks and music would flow. However, after 24 seconds (consistently so) the speakers would make a crackling sound and the music would fade away to nothing. The reset button on the front face has no effect. Only disconnecting from the mains will reset this cycle. And again, only 24 seconds of music before I hear crackle and fade to nothing. On insoection, the main PCB looks to be ok. I have freshened up only a few solder joins which were looking dull. on testing this has had no affect on the issue. Should I take out the power coils and have a look around them too? Has anyone else had similar problems with MCL2P units? I’d love to get this one going. Many thanks, Julian
Some further information: I acquired a 2nd MCL2P (this one works) and have found that the LED on the front changes to green when it’s in use. The first unit I bought which doesn’t work only shows a red LED on the front when powered on.
Does this ring any bells with anyone as to which part of the unit might have failed?Location: Kent, UK
4 June 2022 at 11:06 #34737coolhandxxx
BRONZE MemberHi, I have had the pleasure of owning one of these from new!!!!
Last time I used it I could not get it to work until I replace one of the fuses inside. I suggest you check them first there are three from my recollecting. Surprisingly, having moved house and come to set it up again, I came on to the forum to ask the exact same question you raised….why does the sound keep cutting out. I have discovered that it has a feature:
“Automatic Power Handling Control which automatically turns down the volume when amplifier has been overloaded”
But sadly this is as far as I have progressed. I have tried 2 different sets of speakers with sound input generated from two different phones and a DAB radio but still have the same problem. Ill let you know if I find a solution
