Home › Forums › Product Discussion & Questions › Other › Masterlink ceiling speakers + 1611 Adapter
- This topic has 7 replies, 2 voices, and was last updated 2 weeks ago by
Madskp.
8 July 2025 at 21:21 #66872
Josef Schnieders
BRONZE MemberHello everybody,
I’ve just registered, as I have a question that I can’t find an answer for. I hope you can forgive me for my lack of knokledge about the B&O system and terminology. Hence the reason I chose this sub-forum.
I have some ceiling speakers split in 3 zones (each zone with one IR Eyelet), which were controlled by a BeoSound 3000 (or a similar model with Masterlink and CD), but that one move a floor further downstairs.
So I got myself a 1611 adapter, which is working fine with being supplied by a Wiim streamer.Now to my problem:
I can turn on the zones with both a Beolink 1000 remote or directly on the IR Eyelet (top to bottom: Timer / Vol. up / Vol. down / Play), but every time I have to press ‘TV’ on the remote to hear the music been streamed.Is there a way to set the Eyelets to remember the correct channel, so I don’t need to use the remote every time I hit ‘Play’ on an Eyelet?
9 July 2025 at 15:23 #66877Madskp
GOLD MemberThe link room IR eye buttons will default to Radio if nothing is already playing.
Since you use the 1611 converter there is no real source, but the 1611 can select between a Video or an Audio input on the AAL connector. Wheether it is an audio or a video input is defined by how your cable between the streamer and the 1611 is wired. See this for a sketch with the two inputs and how they are wired https://forum.beoworld.org/forums/topic/beolab-3500-and-1611-converter-settings/page/22/#post-42623
In your case the cable is most probably wired for the video input, thus you have to press TV or any other video source on a remote to activate that input.
If you get a correct wired cable you can use audio commands instead, and I belive the buttons on the IR eye will activate that input.
I can try to test this some time next week if you want to have confirmed that it will work.
Hope this helps with this issue
GOLD MemberA cable like this https://www.amazon.co.uk/kenable-Degree-Phono-Female-Sockets-Red/dp/B06XDXJLHR can be an easy way to utilise both inputs on the 1611 converter
Location: Denmark9 July 2025 at 18:13 #66883Josef Schnieders
BRONZE MemberMy cinch to Aux cable is connected like this (attached photo), which looks like it’s connected as TV input.
That adapter looks like a solution, I’ll have a look if it’s available in Germany (or EU).
You must be logged in to view attached files.9 July 2025 at 19:06 #66885Madskp
GOLD MemberThat adapter looks like a solution, I’ll have a look if it’s available in Germany (or EU).
It should be. I just searched for 5 Pin DIN 4 RCA
Location: Denmark9 July 2025 at 20:20 #66889Josef Schnieders
BRONZE MemberYes, ordered one an hour ago on ebay, ~7€ including shipping.
I’ll post an update after I’ve tested it.
15 July 2025 at 18:56 #67163Josef Schnieders
BRONZE MemberHi Madskp,
the adapter cable arrived today and it works like you said. I just had to use the black and yellow connector. The sound starts by only pressing “Play” on the IR eyelet.
Thanks again for the competent support, much appreciated.
This reply was modified 2 weeks ago by
Josef Schnieders.
15 July 2025 at 20:28 #67182Madskp
GOLD MemberGood to hear it worked out succesfull 😀
As an added bonus you can use the 2 other connectors for an extra source (computer, phone, MP3 player, Record player etc.) that can be activated with the TV command if needed
