Home › Forums › Product Discussion & Questions › BeoLink › Master link Audio Master
- This topic has 5 replies, 3 voices, and was last updated 3 years, 1 month ago by
Frog.
13 February 2023 at 02:04 #43812
Frog
GOLD MemberHi,
what is the easiest way to add the signal in Masterlink to convince other devices that a ML Ausio master is attached?
I note that in the ML/NL converter you can get a box that will do that, but what does it do?
maybe it would be easy to make one? Any idea of what voltage and what wire on the ML connector is needed?
13 February 2023 at 16:07 #43813Madskp
GOLD MemberIf I understand you correct it might be the 1611 Beolink converter you are looking for. Take a look in this rather long thread
https://forum.beoworld.org/forums/topic/beolab-3500-and-1611-converter-settings/page/4/
it will give both a audio and a video source availeble on Masterlink.
Meaning you can from a Beovision with masterlink press any audiosource button and the 1611 Beolink converter will activate the correct input pins (1, 4 and 2 for audio) in its datalink connector.
Also see Matadors very informative drawing where it is used with a Beolab 3500 as a stand alone solution https://forum.beoworld.org/forums/topic/beolab-3500-and-1611-converter-settings/page/4/#post-14017
14 February 2023 at 12:53 #43814Frog
GOLD MemberI think what you are saying is that if I attach a 1611, then I won’t need an audio master? I’m not using datalink, just ML and NL.
14 February 2023 at 13:19 #43815Madskp
GOLD MemberI think that would be the case depending on your setup and goal. My knowledge of the ML/NL converter is limited, so my answer is for the ML part.
in the linked thread it was tested with both Beolab 2000 and 3500 as well as different Beovisions and a Beport without other components in the Masterlink chain.
14 February 2023 at 15:12 #43816 MillemisBRONZE MemberI think what you are saying is that if I attach a 1611, then I won’t need an audio master? I’m not using datalink, just ML and NL.
That is what the ML-Powerbox does.
This was introduced at a time where B&O did not make the 1611 anymore.MM
22 February 2023 at 00:57 #43817Frog
GOLD MemberThanks.
