Home › Forums › Product Discussion & Questions › BeoCenter › Master cable plug
- This topic has 5 replies, 3 voices, and was last updated 1 year, 3 months ago by
beouser19.
16 December 2024 at 09:35 #61657
stotty1111GOLD MemberAnyone know or have ideas where I can get a new plug?
One end of the cable, the plug is beginning to disintegrate!
16 December 2024 at 15:36 #61672Madskp
GOLD MemberThey can be found on ebay, but a special crimping tool is needed.
Another option could be to get a small piece of masterlink wire with a plug and splice the new cable with the existing one for example with a ML junction box or soldering and heat shrinking the connections
16 December 2024 at 19:06 #61675 stotty1111GOLD MemberI think a little confusion rules, I am looking for the plugs or the link cable between the head unit and the master box
16 December 2024 at 19:10 #61676Madskp
GOLD MemberOh its for the Beocenter 2, in that case I am not sure you will be able to find the plugs separatly. So you might go for a new cable
20 December 2024 at 10:16 #61789 stotty1111GOLD MemberOk, thanks
23 December 2024 at 21:38 #61885beouser19
MemberYou need to buy a complete cable the plugs for beocenter 2 cannot be bought
