Home › Forums › Product Discussion & Questions › BeoCenter › Making AUX input work on Beocenter 9300
- This topic has 1 reply, 2 voices, and was last updated 1 hour, 14 minutes ago by
lausvi.
1 December 2025 at 14:08 #71617
Sebastien
BRONZE MemberHi everyone
I recently acquired a Beocenter 9300, and I’m trying to connect a Bluetooth Receiver/Transmitter to the AUX input. The BT device works (I’ve been using it on my previous Hifi amplifier); it connects via RCA, so I’ve purchased an RCA – 7-pin DIN cable, and I’ve connected it into the TV/AUX input on the back of the Beocenter 9300. When I turn everything on, connect my phone into the BT device, and start streaming, the AUX does not activate on the Beocenter; and I can’t activate it manually (pressing the AUX touch-button doesn’t do anything). Since I don’t have a remote control for the Beocenter, what do you suggest I do to activate it?
Thanks for your help!
Favourite Product: Beocenter 9300
1 December 2025 at 16:51 #71618 lausvi
BRONZE MemberOnly a B&O-product would talk Beolink, and make the BC to start from an input, it won’t start by an incoming audio signal only.
Do the other input or the standby touch-button work? Can you test it in TAPE2? The glass panel with the touch-buttons might be loose (due to aging of the double-sided tape that holds it into the frame) and the glass might have lifted on the edge of the glass panel causing the touch-buttons not to work (or needing a stronger push to first push the glass panel back down to the original position).
