Home › Forums › General Discussion & Questions › General Discussion & Questions › low volume when playing PCM 2.0 on Theatre
- This topic has 5 replies, 4 voices, and was last updated 2 years ago by
solidkd.
6 May 2024 at 04:21 #55220
solidkd
BRONZE MemberHas anyone experienced the issue of low volume when playing PCM 2.0 on Beosound Theatre?
6 May 2024 at 10:46 #55224 bsantini1BRONZE MemberYes. Low volume on PCM 2.0
8 May 2024 at 03:15 #55366 Severed_hand_of_skywalkerBRONZE MemberYou have the latest firmware?
8 May 2024 at 18:01 #55398Sandyb
BRONZE MemberIndeed – I thought the low volume on PCM 2.0 had been solved a couple of SW versions ago?
Remember that when they “fixed 2.0” last year, they somewhat broke DD 5.1 and gave that format a low volume issue.
The recent update – where volume gain can be applied by default per source – was supposed to alleviate the low volume issues generally.
Personally, not noticed 2.0 low volume – while the perceived volume seems quite variable even amongst different 2.o signals, if anything for me 2.0 can if anything be pretty loud in my setup / case.
11 May 2024 at 02:39 #55456solidkd
BRONZE MemberOn Severed_hand_of_skywalker saidYou have the latest firmware?
3.4.2(6)
23 May 2024 at 08:10 #55910solidkd
BRONZE MemberThe issue has been resolved. I foundthat when my streaming device outputs PCM 2.0 audio without CEC enabled, the device itself has a separate volume control. By adjusting the volume to a normal level using its remote control, everything is back to normal.
