Home › Forums › Product Discussion & Questions › BeoSound › Lossless Apple Music to Beosound core?
- This topic has 29 replies, 7 voices, and was last updated 8 months, 3 weeks ago by
Erik.
27 November 2023 at 21:09 #50764
Mark
FOUNDER MemberI haven’t studied them but I did look through them. I could have missed it but I didn’t see anything about “bit rate”. The third link does mention “sample rate” but that does not indicate if it is lossy or not.
In my library I have CDs that I ripped to AIFF that shows up as:
bit rate. 1,411 kbps
sample size 16 bit
sample rate 44.100 kHz
and iTunes purchases that show up as
bit rate. 256 kbps
sample rate. 44,100 kHz
If I understand this correctly it is the bit rate that tells you if it is lossy or not…
27 November 2023 at 21:25 #50765Sandyb
BRONZE MemberNot sure whether you are using Apple’s Music app to air play / stream out your ripped library or something else. But if its Apple’s Music app, as mentioned before, it will get downsampled from 16/44, as we know that in this stream case Airplay 2 (from the Music app) does not stream out at 16/44.
I think thats really all that matters, as it relates to your initial question (relating to your library of 16/44 CD rips).
27 November 2023 at 21:32 #50766Mark
FOUNDER MemberBut if its Apple’s Music app, as mentioned before, it will get downsampled from 16/44,
What does it get downsampled to?
All my (few) MP3’s show the sample rate of 44,100 kHz, with no sample size, so I don’t know if this (alone) is any indication of lossless or lossy. If lossy what is the bit rate?
27 November 2023 at 21:40 #50767Mark
FOUNDER MemberI wonder if the bit rate, sample size, and sample rate could be added to the signal info for the device in the B&O app?
27 November 2023 at 22:37 #50768Sandyb
BRONZE Memberhttps://darko.audio/2023/10/apple-airplay-isnt-always-lossless-sometimes-its-lossy/
Your answer is here.
27 November 2023 at 23:02 #50769Mark
FOUNDER MemberI always hope that Apple can improve Airplay 2 performance. Whatever is going on behind scenes is not always easy to determine, which is why I would love to see more information added to “Signal info” in the B&O app for each device, if possible to do so.
27 November 2023 at 23:24 #50770Sandyb
BRONZE MemberSure, and Apple have doubtless had feedback about making Airplay 2 + Apple Music 16/44 capable (or higher).
But there’s a pretty obvious reason why they haven’t – they’re a mainstream company, and too few actually care enough, given modern music listening habits.
As for signal info, while it would be nice for the B&O app to show signal info when it comes to music, when it comes to your (what I interpret as your) case – using the Music app to airplay (2) stream your ripped CDs, then we already know the answer to be 256 (according to the article I posted, and others).
There’s a reason why some who have more particular needs – wanting to stream their own CDs rips, and / or have long wanted to stream CD or above from whichever service provider – tend not to use Apple Music.
27 November 2023 at 23:34 #50771Mark
FOUNDER Memberwe already know the answer to be 256 (according to the article I posted, and others).
Adding this information to signal info would only confirm what they state, which I don’t think would be a bad thing.
27 November 2023 at 23:54 #50772Mark
FOUNDER MemberWhile I don’t out-right disagree with any of these testing methodologies there are many variables involved that could affect the outcome. It would be nice if there are tools available where we can each know for sure in our environment.
17 August 2024 at 11:16 #58384Erik
BRONZE MemberHere is an article with a breakdown, what Airplay combinations are lossless and which are not: Lossless AirPlay updates from Roon, Tidal and RoPieee | Darko.Audio
AirPlay 1 app mode –> AirPlay 1 endpoint LOSSLESS
AirPlay 2 app mode –> AirPlay 1 endpoint LOSSLESS
AirPlay 1 app mode –> AirPlay 2 endpoint LOSSLESS
AirPlay 2 app mode –> AirPlay 2 endpoint LOSSYAccording to this article Apple AirPlay isn’t always lossless. Sometimes it’s lossy — but why? | Darko.Audio
The bottom line: it’s only when
- the streaming app,
- the iPhone/iPad model on which that app runs and
- the streaming endpoint
are all AirPlay 2-equipped that the stream is lossy compressed to AAC 256kbps.
