Home › Forums › Product Discussion & Questions › BeoCenter › Looking for a tool to adjust Beocenter 2 distance between Keyboards and Display
- This topic has 0 replies, 1 voice, and was last updated 3 weeks, 5 days ago by
Jan.
Viewing 1 post (of 1 total)
29 January 2026 at 23:02 #72956
Jan
BRONZE MemberDag,
I am looking for a tool to adjust my Beocenter 2 distance between Keyboards and Display. Use the special tool delivered with the gearbox. Witch tool should I use?
After replacing parts in the Master unit, it may be nessasary to adjust the Keyboards. There are two adjustments:
1. Distance between Keyboards and Display.
2. Distance between Keyboards and bottom.
To adjust the distance between the display and the Keyboards (a), use the screw 1 (Located on the back). Use the special tool delivered with the gearbox.
