Home Forums Product Discussion & Questions BeoGram Liquid Filled LP’s
  • #71971
    Frank Ferrantelli
    Thes new liquid filled LP’s seem to be a lot heavier than the 180g presses they are putting out now. I have a BEOGRAM 2404, and was wondering if the weight will affect playback? Should these releases just be avoided? Thanks.
    #71979
    Mark-sf
    They should not be a problem unless your suspension is adjusted low. If you can put 2 normal records on without bottoming you should be fine. In any case, you’ll not damage anything.
    #72007
    AdamS
    As above, it should be absolutely fine. Just be careful with any unduly heavy 7″ records on any Beogram that uses weight for size sensing – you don’t want them thinking they’re a 12″ and dropping the stylus accordingly.
    Ask me how I know – fortunately I caught the arm in time!
