Home › Forums › Product Discussion & Questions › BeoVision › LG software update affecting TV control
- This topic has 4 replies, 2 voices, and was last updated 6 months, 3 weeks ago by
Mbee.
27 August 2025 at 19:05 #69117
patcherley
GOLD MemberMy Eclipse had an LG software update last night and since then my Beoremote can only control the HDMI sources attached to the Soundcenter. I reported this to B&O and they have confirmed the software update caused it and they are working on a solution.
Here is the link to the announcement which includes 2 work rounds https://support.bang-olufsen.com/hc/en-us/articles/20651659644561-Important-news
I will let you know when I know more.
Paul
Favourite Product: Beolink 7000
11 September 2025 at 15:43 #69544patcherley
GOLD MemberJust had an update from LG and it now seems to be back working
13 September 2025 at 19:10 #69623Mbee
BRONZE MemberThanks,can you give me the buggy version number (23.25.55?), and the new version number ?
13 September 2025 at 20:31 #69637patcherley
GOLD MemberHi, the buggy version was 23.25.50 the new version is 23.25.55. Hope that helps. Paul
14 September 2025 at 22:00 #69674Mbee
BRONZE MemberThanks,and what are the symptoms on your TV?Because on mine,after a bit more than an hour usually, I get a message « network lost » and then « network connection reestablished » again and again until the soundcenter crashes and I get only sound from lg speakers. But I think it may be related to a hardware fault on my side.
