Home › Forums › Product Discussion & Questions › BeoSound › Theatre › Lan connections on Theatre
- This topic has 1 reply, 2 voices, and was last updated 2 years, 8 months ago by
reno.
16 July 2023 at 01:32 #47667
bsantini1BRONZE MemberI know that one of the four LAN inputs is labled for direct connection to a LG TV. Another is labeled “In”. What is that for? Is it for attaching a LAN cable from the router? If so, then are LAN labels “2 & 3” for routing internet to other components? Thank you in advance for your help.
16 July 2023 at 15:14 #47668reno
BRONZE MemberAs you say yourself, “in” is from the router and 2/3 are for other devices – I myself have set AppleTv to 2.
Just got my Theater set up myself – enjoying it every day
