Home › Forums › General Discussion & Questions › BeoWorld Feature / Problem › Lab 28’s Curtain Control
- This topic has 1 reply, 2 voices, and was last updated 9 months ago by
Peter Fraser.
28 May 2025 at 10:19 #65860
George Wallwork
GOLD MemberMy lab 28’s are connected using wireless link to the Theatre. When I select TV mode, I have configured for just the Theatre speaker to be active. However, the curtains also open on the 28’s. No sound comes from the 28’s on TV mode and only the Theatre works, which is correct and exactly what I have programmed it to do when the source is TV.
What I’m asking: is there a way to have the curtains stay closed or close when the selected source does not require the 28’s and only activate if the source requires the 28’s and then close if the source does not require it. I think this adds to the ‘wow’ factor. Interested to know if this is an option.Location: Melbourne Australia
Favourite Product: Beolab 28
26 June 2025 at 14:13 #66672Peter Fraser
ModeratorHello George,
This issue is standard behaviour on all Wireless Power Link speakers due to TVs/Theatre sending data in all speaker setups at start-up, which causes all speakers to switch on briefly.
Work Around
The only known workaround is to use wired Power LinkKind regards,
PeteSignature: Peter Fraser
Service Technician
Multicare Electronics -
