Home › Forums › Product Discussion & Questions › BeoSound › Issues with the Beosound 5 Encore
  • #126005
    Nordmann
    Hi everyone,
    I received a Beosound 5 Encore and am having some trouble getting it to work. I hope you have any idea what might be wrong with the device.
    1. In the main “Mode” menu, only Radio, A.Aux, and Settings are displayed—no N.Music, even when I plug in a USB drive.
    2. Network settings: DHCP enabled / Network Connection: Yes / IP address is present
    3. Roles: N.Music
    4. Under Maintenance -> About -> Cryotec 1.0.0 – Software Update -> no new software
    The Encore doesn’t detect a USB flash drive and apparently can’t connect to the Beomaster 5 (Service Settings – Music Storage).
    When I select a radio station, the radio name flashes and no logos appear.
    I’ve already performed a reboot and a factory reset, but unfortunately without success.
    Is there a way to reinstall the software or get the system up and running some other way? I’d appreciate any advice.
    Thank you
    #126105
    Jan
    About the USB-drive. I’ve had some trouble with it and after using a 16 GB USB-drive Sandisk Cruser Blade it works.
    Using  Kingston 64 GB USB ditn’t work. It wasn’t reading it. Even after a factory reset.
    An other problem is. When you add new music to the USB-drive it will not recognise the new added music until I reset the Encore to factoryreset.
