Home › Forums › BeoWorld around the world! › Dutch › Is Beosound5 wallbracket the same as tablestand?
- This topic has 2 replies, 2 voices, and was last updated 7 months, 2 weeks ago by
carolpa.
13 August 2025 at 13:49 #68751
Joris Allewijn
BRONZE MemberHi there, I’m new here. Bought a Beosound 5 with tables tandem. I rather like it to hang on the wall (under an angle) Can I just turn around the tablestand 180 degrees? If so, how to? Thanks in advance. Greetz Joris
Favourite Product: Beosound 5
16 August 2025 at 12:27 #68812Joris Allewijn
BRONZE MemberHello, I just received from support Bang&Olufsen that this is not possible. The tablestand and wallbracket seem to be different.
greetz, Jos
16 August 2025 at 16:38 #68820 carolpaBRONZE MemberHello, I just received from support Bang&Olufsen that this is not possible. The tablestand and wallbracket seem to be different.
greetz, Jos
They look almost the same, but the weight difference in enormously because you need some contra weight to balance the BS5 standing free.
the wallbracket is made of plastic, the table stand of metal. -
