Home › Forums › Product Discussion & Questions › BeoCenter › IR sensor does not work on Beocenter 2300
- This topic has 1 reply, 2 voices, and was last updated 11 months, 3 weeks ago by
Madskp.
12 April 2025 at 18:30 #65077
Kjell-Åke Rydén
BRONZE MemberJust bought a Beocenter 2300 and it will not take the commands from working remotes (tried several). Any idea how to fix?
12 April 2025 at 18:44 #65078Madskp
GOLD MemberIf it has been used in a setup with a Beovision TV before it is very likely that it is setup to option 0 (no IR)
So first thing is to try to set it to option1 instead.
With a beolink 1000 it is done by pressing Sound, 1, Store
If you have a Beo4 remote press the Standby button and LIST at the same time. Then press LIST until OPTION is shown in the display. Then press GO (centre button), and then press LIST to show A.OPT. Then press 1.
The Beocenter will blink with the red LED to confirm the option setting change
Hope this helps
