Home › Forums › BeoWorld around the world! › Nordic › Input connection Beosound Core
- This topic has 2 replies, 3 voices, and was last updated 1 year ago by
Leosgonewild.
10 January 2025 at 22:03 #62510
Øivind Friksen
BRONZE MemberHi All 🙂
Is it only minijack i can use as input? Sound is delayed when i use it from TV to the core. The Optical is only for output?
Best Regards
10 January 2025 at 22:13 #62513DT79
BRONZE MemberThe minijack connector is a combo 3.5mm analogue jack and optical input. You can connect optical from the TV to it with a suitable toslink to 3.5mm cable or adaptor for a regular toslink cable.
10 March 2025 at 01:58 #64415 LeosgonewildBRONZE MemberIn the setting, go to line in and disable delay. That will fix your sync problem.
