Home › Forums › Product Discussion & Questions › BeoSound › How to use BV7 and BS Essence MKII together?
- This topic has 21 replies, 3 voices, and was last updated 3 years, 4 months ago by
tux.
29 November 2022 at 19:52 #40736
carolpaBRONZE Memberdepending on your needs you got two options.
- remove the Ouverture and go back to the first discussed setup (BLC A.Master) or
- buy a PL to AUX cabel and connect the Essence to the AUX of the Ouverture
1 December 2022 at 17:19 #40737tux
BRONZE MemberI can’t connect the Essence and Ouverture together because they are not in the same room and there is no MasterLink cable in the room where the Essence is installed.
Therefore, I’m going remove the Ouverture from the MsaterLink and try again. But, I fear, this will not solve my problem as I already tried this setup (BLC as Audio master) without success.
May the force be with me!
Anyway, I thank you for your support Carolpa.
