Home › Forums › Product Discussion & Questions › BeoLab › How to Connect Beolab 14 to a streamer and a TV
- This topic has 4 replies, 3 voices, and was last updated 2 years, 10 months ago by
Tommi Mannonen.
9 June 2023 at 07:29 #47084
Tommi Mannonen
BRONZE MemberI have Beolab 2.1 system and used to connect wireless with phone and Ipad to play music and TV was also part of the system. All were connected with Playmaker. Now my playmaker seems to be “dead” and I should replace it with something.
All remain the same except that I now have a Samsung Frame with optical and HDMI (arc also).
What would you recommend for me for this setup?
9 June 2023 at 21:11 #47085 MillemisBRONZE MemberThis one may be an option:
https://hallaudio.com/en/produkter/traadloes-streaming/hall-wifi-streamer/
10 June 2023 at 08:51 #47086 Steve at Sounds HeavenlyGOLD MemberHi Tommi,
Either the B&O Core (if funds allow) or the cheaper Connection Hub should work well for this. The Core has a streamer built in, whereas the Hub has optical and analogue audio connections to allow you to connect a separate streamer as well as the TV.
Kind regards, Steve.
13 June 2023 at 07:49 #47087Tommi Mannonen
BRONZE MemberThanks for the suggestion, really helps!
13 June 2023 at 07:50 #47088Tommi Mannonen
BRONZE MemberThanks for the advice!
This is a new model for me, but certainly a valid option.
Tommi
