Home › Forums › Product Discussion & Questions › BeoLab › How to best connect BL 18 to LG C1
- This topic has 9 replies, 5 voices, and was last updated 2 years, 6 months ago by
Hereford.
8 January 2024 at 09:58 #51997
jacob117
BRONZE MemberHi,
What are the best options to connect Beolab 18 to LG C1 TV?
8 January 2024 at 12:53 #51998 Tignum
GOLD MemberHello jacob117, not sure if it is ‘best’, but both the TV and the speakers support WiSA, right?
Regards, Johan
8 January 2024 at 15:14 #51999Curly
BRONZE MemberJacob, I’ll make a suggestion, which I suspect is one not thought of often: S8 Connection hub.
This piece is made specifically to connect a L and R BeoLab in stereo configuration to nearly any TV and allow you to use your existing TV remote control to adjust volume. Give it a Google.
8 January 2024 at 15:50 #52000 MillemisBRONZE MemberHi, What are the best options to connect Beolab 18 to LG C1 TV?
Wired or wireless???
9 January 2024 at 08:13 #52001jacob117
BRONZE MemberWell I tried WISA when it first came out on the C9 with the WISA dongle, and lets just say I was not impressed. But I might be wrong now, perhaps its gotten much better than at that point?
Preferably would be wired connection, I have seen this Hall wifi streamer thing that should do the job for a reasonable price, but I’m unsure if the sound is any good.
I also have a Beolab 2 I would like to add to the setup, but I guess that would be easy to extend from BL18 power link with both solutions.9 January 2024 at 09:33 #52002 MillemisBRONZE MemberI can assure you that the Hall device ‘sounds good’ – I have set up a few of those.
I still have the one I originally bought for testing – although no need for it at the moment, I will keep it…..just in case.Just use a splitter cable – which can be ordered with the device, if you’d need one.
Basicly, adding a sub like the BL2 needs a bit of experimenting to find the right spot in the room in order to minimize room mode problems.
9 January 2024 at 10:08 #52003jacob117
BRONZE MemberPerfect, I will go with this solution then.
I experienced way to many problems with the Axiim link and WISA dongle and I don’t wanna go there again.
10 January 2024 at 10:54 #52004jacob117
BRONZE MemberVirker Volume kontrol egentligt fint med ARC forbindelse til Hall devicen?
10 January 2024 at 13:50 #52005 MillemisBRONZE MemberVirker Volume kontrol egentligt fint med ARC forbindelse til Hall devicen?
Ja!
Yes, I did not notice any problems there.
Just use the remote of the tv.MM
15 January 2024 at 12:20 #52006Hereford
BRONZE Memberif you’re at all interested in “unlocking” the world of Atmos audio, you might consider the expensive solution; getting a Theatre.
