Home › Forums › Product Discussion & Questions › BeoSound › How many Aux inputs can work with a Beosound/Beomaster5
- This topic has 6 replies, 2 voices, and was last updated 1 year, 1 month ago by
Madskp.
5 February 2025 at 22:27 #63449
Allan Queen
SILVER MemberHi there,
New member here & I am hoping someone can assist.
I have had a Beosound/Beomaster 5 for many years and I already have a Behringer UFO202 purchased through Sounds Heavenly that I use to connect to Streaming services through one of the USB ports. I am thinking of purchasing a second hand B&O turntable to get back into vinyl. My question is how I can connect a turntable to the Beosound/Beomaster 5. The are no phono plugs to use, and although there are extra USB sockets I could use, there is only one A-Aux choice I can choose on the Beosound 5. Any suggestions? Could I do something through a Masterlink connection?
Thanks in advance
6 February 2025 at 07:28 #63454Madskp
GOLD MemberIt should be possible to get extra sources via Masterlink by the use of a Beolink Converter type 1611.
If you connect the converter via Masterlink the BS5 should be able to get the input from the AAL conector by using video commands like TV, V.MEM, DTV (it does not matter which video command is used) etc. This of course require that you do not have a B&O TV in the same room that also use these commands.
I did some testing of it int this thread https://forum.beoworld.org/forums/topic/beosound-5-a-mem/ where I also tested other possibilities.
If you need more info I can try to do a new test just to verifiy that I was not overlooking something when I did the testing in that thread.
6 February 2025 at 19:37 #63480Madskp
GOLD MemberI just tested this again with the BS5 setup as Audio master in option 2 connected to a Beolink Converter type 1611, and I can indeed get audio input from the 1611 AAL connection when I press TV or any other video command on a remote.
With these settings eventual link rooms should also work in this setup
6 February 2025 at 21:35 #63485Allan Queen
SILVER MemberMany thanks for the input Madskp – most appreciated. Having done a quick search on Ebay, I can see there are many different versions of Beolink Converter and the 1611 isnt that common, at least in the UK. Is there a particular reason for choosing the 1611? I feel a new rabbit hole opening up! I need to do some research on how Masterlink works.
7 February 2025 at 15:18 #63521Madskp
GOLD MemberHi again. I just tested the setup with a Beolink converter type 1614 and that also works. A type 1612 is identical to 1611 but for the US market so that would also work.
Hope this help to narrow it down
8 February 2025 at 22:53 #63596Allan Queen
SILVER MemberThanks Madskp, yes it does help a lot. I will keep a lookout for a suitable unit on ebay etc. Do you know if I connect something like a Beogram 2000 (which has no preamp) to the Beolink converter will I also need to add a preamp or will the Type 1611 boost the signal.
9 February 2025 at 10:14 #63604Madskp
GOLD MemberYou will still need the preamp. The beolink converter only convert the signal types, no amplification
