Home › Forums › General Discussion & Questions › General Discussion & Questions › home cinema Almando
- This topic has 1 reply, 2 voices, and was last updated 1 year, 4 months ago by
TinusAMS.
17 November 2024 at 08:56 #60966
dueno
GOLD Memberhi,
do any of you use the almando solution to make home cinema with bang&olufsen?
What do you think of it?
thanks.
17 November 2024 at 09:35 #60968TinusAMS
BRONZE MemberI had the Almando Multiplay Surround Decoder with WiSa with a Sony A90J and Beolab 28’s.
It was not a good marriage with the Sony tv, E-ARC constantly lost it’s handshake, so no sound. ARC worked fine. Although there’s a delay in turning on/off the tv and the 5v trigger to the 28’s in my case. So the 28’s closed after 10+ seconds after the tv was off. Which kinda killed the B&O magic for me 😉 The sound quality was noticably worse via ARC though. To be honest, it could have been a Sony issue, but I was not satisfied. My dealer had lot’s of clients where it worked perfectly.
Hall Audio WiFi Streamer is an alternative solution with 5v trigger for B&O and it’s cheaper as well.
