Home › Forums › General Discussion & Questions › Home Automation › Home Automation
- This topic has 8 replies, 5 voices, and was last updated 2 hours, 48 minutes ago by
kknyc.
5 March 2025 at 19:00 #64353
Frog
GOLD MemberThere used to be a very useful home automation section in the old forum. I can’t seem to find it any more, but would ask that it is added anyway (even if it isn’t populated with the old messages).
I use home assistant with my ML and NL stuff – along with voice control to really bring my home up to date, but using classic equipment.
5 March 2025 at 19:27 #64354 Severed_hand_of_skywalkerBRONZE MemberI also have home assistant but it only seems to work with my newer Mozart B&O stuff. Did you have success with older hardware?
5 March 2025 at 19:27 #64355 Severed_hand_of_skywalkerBRONZE MemberI also have home assistant but it only seems to work with my newer Mozart B&O stuff. Did you have success with older hardware?
5 March 2025 at 19:32 #64357Frog
GOLD MemberYes.
check out https://github.com/giachello. He has two integrations which I use (I have a ML Gateway) and works really well.
5 March 2025 at 20:51 #64359 multicareGOLD MemberHi,
Happy to add a Home Automation section.
Is there any preference as to where it should be added?Should it be under general or product discussion
6 March 2025 at 09:14 #64360Frog
GOLD MemberI have no preference personally
6 March 2025 at 11:35 #64365 multicareGOLD MemberHome Automation forum created under General Discussion.
Thi topic have been move into the new forum.
9 March 2025 at 10:16 #64397 YannChrisFOUNDER MemberHi all,
Good idea to create this sub-forum.
I’m new to home assistant, it’s running on a QNAP Nas and for the moment it just used for hue lights.
I would like to extend this system to my B&O gear but have no idea of what is possible and how to do.
So I’m open to any information and/or help on these subjects.
Kind regards,
Yann.
26 November 2025 at 18:31 #71558kknyc
SILVER MemberRE: BEOsystem 5500 to Smart speakers
HI BEOWorld,
I just inherited my uncle’s BEOsystem 5500 with two enormous JBL cabinets. But Im currently setup with smart speakers in my apt . Is there a Bluetooth “Transmitter” for sending the BEO audio around the house to smart speakers? For better or worse, Im locked into the Apple ecosystem and would hope to find a DIY or compatible product in 2025
(Im still unsure if I’d utilize the Speaker 2din ports or some other BEOMaster connection to a ‘transmitter’ unit)
Thanks for any insights!
