Home › Forums › Product Discussion & Questions › BeoLab › Help with beolab 4000
- This topic has 2 replies, 2 voices, and was last updated 1 year, 4 months ago by
chris Martin.
8 November 2024 at 22:00 #60777
chris Martin
BRONZE MemberHi i am experiencing random sound cut off on one of my Beolabs 4000. The sound disappears, can come back, just randomly comes and goes.
I changed the rca cable, opened the unit ( foam is fine it is the new one),checked for any loose cable, cleaned contacts with alcohol, sprayed the power switch with contact cleaner, nothing helps.
Any ideas ?
Chris
9 November 2024 at 12:20 #60780mcevedy@mac.com
GOLD MemberI would suggest swapping it from right to left just to check it is not the source – I guess you have done this already – in which case I can only imagine there is a fault in the amplifier – will need service – from experience, Multicare know what they are doing. About to take one of my Pentas in which has done something similar!
9 November 2024 at 12:39 #60781chris Martin
BRONZE MemberOk thanks for your input and quick reply.
regards
chris
