Home Forums Product Discussion & Questions BeoLab Help to connect Beolab 11
Viewing 7 posts - 1 through 7 (of 7 total)
  • #73502
    RAFA1986
    Hello,I recently bought a BeoLab 11 to add to my BeoLab 8000 setup, which is currently working connected to the TV through a DAC.
    What connections and cables should I use to make this change?
    I searched here on the forum and didn’t find anything similar to my case. If I didn’t search properly, I apologize for that.
    Thank you for the support.
    </article>
    • This topic was modified 3 weeks ago by RAFA1986.
    #73533
    Millemis
    I guess this will answer your question.
    #73538
    RAFA1986
    Thank you for your answer.  😊
    Unfortunately, I found out that if I use the LINE setting on the Beolab 11, the sound won’t come out through the two Power Link interfaces that connect to the Beolab 8000.
    The best solution I came up with was to use two 1:2 RCA splitters. Then I connected the L from the Beolab 11 and the L from the Beolab 8000 to the L of the DAC, and the R from the Beolab 11 and the R from the Beolab 8000 to the R of the DAC.As for the cable, I built the 8-pin DIN cable myself (pins 2, 3, and 5), connected from the IN of the Beolab 11 to the two male RCA connectors that go into the splitter, as I mentioned before.
    With these connections, everything works. But with this setup I’m facing the problem of a ‘hmmmm’ noise 😑.
    • This reply was modified 2 weeks, 6 days ago by RAFA1986.
    #73693
    RAFA1986
    Hello,
    Can anyone advise me on how to solve the ‘hmmmm’ noise problem?
    Could I be dealing with a ground loop issue?
    I drew my setup… I couldn’t connect it any other way. Could someone advise me on a better solution?
    I’d really appreciate it if someone could share their knowledge with me.
    • This reply was modified 2 weeks, 4 days ago by RAFA1986.
    #74358
    RAFA1986
    Update
    I have already managed to connect the system as suggested in the Beolab 11 manual (LINE mode on the Beolab 11 → Beolab 8000 MK1 connected to the Beolab 11 outputs).
    However, there is one detail: the Beolab 11 in LINE mode is always active (green LED), and the Beolab 8000 speakers also remain active even when the DAC is turned off.
    How can I solve this problem?
    Do I need to switch to PowerLink mode and use an RCA-to-PowerLink adapter with trigger?
    I don’t want the system to stay ON all the time.
    Can anyone help me?
    Thank you
    RAFA
    • This reply was modified 5 days, 3 hours ago by RAFA1986.
    #74420
    Tignum
    GOLD Member
    Hello RAFA 1986, the BeoLab 11 is said to have line-in sensitivity: it switches on when there is a sound signal detected (and off when there is not).
    Do the 11 & 8000s switch off when you unplug the DAC input from the 11?
    Regards,
    Johan
    RAFA1986
    Hi, thank you for your reply.
    This weekend I made good progress and solved all the issues. I believe I connected the Beolab 11 + Beolab 8000 using the best configuration.
    I set the Beolab 11 to Powerlink mode. This required adding a trigger to the cable connecting the DAC to the Beolab 11. The trigger was connected to a smart plug linked to my Google Home Assistant, and now I can turn the sound system ON and OFF using voice commands.
    Kind regards
    RAFA
    • This reply was modified 1 day, 7 hours ago by RAFA1986.
