Home › Forums › Product Discussion & Questions › BeoLab › Help to connect Beolab 11
- This topic has 6 replies, 3 voices, and was last updated 3 weeks, 3 days ago by
RAFA1986.
10 February 2026 at 17:32 #73502
RAFA1986
BRONZE MemberHello,I recently bought a BeoLab 11 to add to my BeoLab 8000 setup, which is currently working connected to the TV through a DAC.What connections and cables should I use to make this change?
I searched here on the forum and didn’t find anything similar to my case. If I didn’t search properly, I apologize for that.
Thank you for the support.
</article>
11 February 2026 at 09:12 #7353311 February 2026 at 10:56 #73538RAFA1986
BRONZE MemberHi,
Thank you for your answer. 😊
Unfortunately, I found out that if I use the LINE setting on the Beolab 11, the sound won’t come out through the two Power Link interfaces that connect to the Beolab 8000.
The best solution I came up with was to use two 1:2 RCA splitters. Then I connected the L from the Beolab 11 and the L from the Beolab 8000 to the L of the DAC, and the R from the Beolab 11 and the R from the Beolab 8000 to the R of the DAC.As for the cable, I built the 8-pin DIN cable myself (pins 2, 3, and 5), connected from the IN of the Beolab 11 to the two male RCA connectors that go into the splitter, as I mentioned before.With these connections, everything works. But with this setup I’m facing the problem of a ‘hmmmm’ noise 😑.
13 February 2026 at 16:51 #73693RAFA1986
BRONZE Member26 February 2026 at 14:46 #74358RAFA1986
BRONZE MemberUpdate
I have already managed to connect the system as suggested in the Beolab 11 manual (LINE mode on the Beolab 11 → Beolab 8000 MK1 connected to the Beolab 11 outputs).
However, there is one detail: the Beolab 11 in LINE mode is always active (green LED), and the Beolab 8000 speakers also remain active even when the DAC is turned off.
How can I solve this problem?
Do I need to switch to PowerLink mode and use an RCA-to-PowerLink adapter with trigger?
I don’t want the system to stay ON all the time.
Can anyone help me?
Thank you
RAFA28 February 2026 at 12:51 #74420 TignumGOLD MemberHello RAFA 1986, the BeoLab 11 is said to have line-in sensitivity: it switches on when there is a sound signal detected (and off when there is not).
Do the 11 & 8000s switch off when you unplug the DAC input from the 11?
Regards,
Johan
2 March 2026 at 11:00 #74662RAFA1986
BRONZE MemberHi, thank you for your reply.
This weekend I made good progress and solved all the issues. I believe I connected the Beolab 11 + Beolab 8000 using the best configuration.I set the Beolab 11 to Powerlink mode. This required adding a trigger to the cable connecting the DAC to the Beolab 11. The trigger was connected to a smart plug linked to my Google Home Assistant, and now I can turn the sound system ON and OFF using voice commands.
Kind regards
RAFA -
