Home › Forums › Product Discussion & Questions › BeoCord › [HELP] Replace IC9 8355 Input/Output in Beocord 8004.
- This topic has 3 replies, 2 voices, and was last updated 2 years, 2 months ago by
Dillen.
29 December 2023 at 03:40 #51647
beolover.vn
BRONZE MemberMy device has an issue with IC9, can I purchase a similar one available on eBay for replacement? Seeking advice. Thank you!
29 December 2023 at 09:13 #51648Dillen
ModeratorIt’s mask programmed by/for B&O.
But these rarely fail.
What are the symptoms?Martin
30 December 2023 at 05:37 #51649beolover.vn
BRONZE MemberWhen pressing play, the motor does not engage, and the heads do not lift up.
30 December 2023 at 08:40 #51650Dillen
ModeratorDoes the display light up ?
