Home › Forums › Product Discussion & Questions › BeoCenter › Help for BeoCenter 9000 tape. Update: it’s not the belt
- This topic has 9 replies, 3 voices, and was last updated 3 years, 9 months ago by
YannChris.
2 July 2022 at 01:56 #35958
YannChrisGOLD MemberUpdate:
I exchanged the belt with a one bought to Dillen a few years ago but never used.
Unfortunately with no complete result : fluctuations while reading are gone but the other defects stay unchanged (see below).
Any clue?
Kind regards,
Yann.
Hello Beoworlders,
The tape unit of my Beocenter 9000 has problems.
Reading works on both sides, but with fluctuations.
The video below shows what happens, using a tork-meter tape (side 2 first, then side 1).
When recording, the “blank” spool turns but the “recorded” one doesn’t in a first step, then turns fast and the recording stops (see video below).
Fast forward and rewind does not work at all, nothing moves.
Could it be the belt (it’s a unit with an unique long belt and 2 screws near the head) or if not what’s your diagnostic?
I bought a spare belt a few year ago but did not find how to change it, as I did not find how to take the tape unit apart.
Any help would be highly appreciated.
Kind regards,
Yann.
2 July 2022 at 14:39 #35959 chartzBRONZE MemberBelts and tyres. You have to do them all.
The place you want to buy from is called Beoparts.
2 July 2022 at 15:36 #35960 YannChrisGOLD MemberThanks Chartz,
What do you mean by tyres?Kind regards,
Yann.
2 July 2022 at 15:58 #35961 chartzBRONZE MemberPlease moderator erase.
2 July 2022 at 16:08 #35962 YannChrisGOLD MemberThanks Chartz,
I just had a look and these parts are for Beocord 9000 and I have a Beocenter 9000
Are you site they are adapted to my set?
Kind regards,
Yann
2 July 2022 at 18:41 #35963 chartzBRONZE MemberAh ok, here BC often means Beocord. My bad, I should have watched the videos. So no.
2 July 2022 at 19:03 #35964 YannChrisGOLD MemberAnd did the videos give you other clues?
3 July 2022 at 14:02 #35965 YannChrisGOLD MemberUpdate:
Unfortunately with no complete result : fluctuations while reading are gone but the other defects stay unchanged.
Any clue?
Kind regards,
Yann.
3 July 2022 at 16:42 #35966Dillen
ModeratorFollowing B&Os system BC are Beocords.
BCT are Beocenters.Martin
(For reasons unknown to me apparently no longer Dillen).3 July 2022 at 17:33 #35967 YannChrisGOLD MemberHello Martin,
Thanks for the info, my mistake is corrected.
Do you have any clue for the remaining problems?
Does the reading of the tork-meter tape video shows something useful?
Kind regards,
Yann.
