Home › Forums › Product Discussion & Questions › BeoSystem › HDMI-ARC on Beosystem 4
- This topic has 8 replies, 6 voices, and was last updated 2 years, 11 months ago by
bulldog123.
27 December 2022 at 03:32 #41850
FrogGOLD MemberTo connect my Beosystem 4 to my LGTV, I use a HDMI splitter, so the video source doesn’t need to go through the Beosystem 4 – allowing 4K.
I was wondering how to make the Beosystem 4 ARC compatible, so I could feed the audio back to the Beosystem 4 and remove the splitter. Most ARC extractors, don’t seem to have a hdmi out – just phono or toslink – which means only 2 channels.
anyone know of a way to use the Beosystem 4 as a client for a ARC TV?
28 December 2022 at 13:09 #41851bulldog123
BRONZE MemberI am also interested in this
28 December 2022 at 19:26 #41852beoandy
BRONZE Memberhi
you can use this earc extractor FeinTech VAX01202. I use this with the beosystem 4 and an LG-G1. the output from the extractor sends a black picture with the sound to the hdmi input of the beosystem 4. so you can get the sound of the sources from the LG TV and the sources connected to it into the beosystem 4. disadvantage: no menu overlay from the beosystem 4 on the tv.
I think you can also use this extractor as a splitter. unfortunately I have no experience with that. my setup runs hd only (all sources connected to the beosystem) and for 4K (only for films) via the extractor and an apple tv directly on the LG-G1 and then the sound via the beosystem4.
the respective switching then makes a beoliving intelligence and the apple tv is then controlled via the puc-ir codes from the beosystem 4.beoandy
29 December 2022 at 12:52 #41853
FrogGOLD MemberThat’s exactly it. Thanks
29 December 2022 at 13:21 #41854kirin
BRONZE MemberHi Beoandy, tat is really a good finding, thanks! Having a Beosystem 3 in the cellar, which is not in use exactly due to this circumstances…
14 February 2023 at 23:49 #41855Chucky
BRONZE MemberI bought 2 they work really well thanks!
8 May 2023 at 09:50 #41856bulldog123
BRONZE MemberI tried the Feintech product and could not get it to work work with my projector Sony VW-VPL590ES. I tried the HD Fury Vertex2 instead – bought from Joe at https://tmfsolutions.co.uk/?s=Hd+fury. with amazing service from Joe and great online support from HDfury the complex setup became a breeze. Now I have 4k pass through to input 1 of the PJ and 1080p video and PCM audio to the Beosystem 4 (1080p video goes into input 2 of PJ so I can still see OSD for volume and the like and view non-4k material via BS4). Appears to be stable after 20 hours of viewing. Great solution and means that my BS4 gets to go on for a few more years yet. Note I have a pair of BL5s in the setup so switching to a non-B&O AVR presented difficulties.
10 May 2023 at 06:02 #41857schanzenbaecher
MemberI am also interested in this setup, but a little bit confused about the connections. What do you connect to HDMI-ARC of the TV and what do you connect to HDMI OUT of the BS4? A drawing of the connections would be very helpful. What means input 1 and input 2 of the PJ?
10 May 2023 at 12:49 #41858bulldog123
BRONZE MemberApologies for any confusion. There is no TV in my setup – only display is a Sony PJ. cabling as follows:-
AppleTV 4K (4k video out)>>via HDMI>> Vertex2 (HDMI0 input)
Vertex2 (TX1 output – 1080p Video & PCM Audio) >>via HDMI>> Beosystem 4 (HDMI Input 5) >> Output via HDMI to PJ Input 1
Vertex2 (TX0 output – 4k Video) >> DIRECT via HDMI >> PJ Input2
Hope this helps.
