Home › Forums › Product Discussion & Questions › BeoRemote › Beo5 & Beo6 › Getting the original BEO5/BEO6 XML files
- This topic has 3 replies, 3 voices, and was last updated 2 years, 10 months ago by
Tah_au.
19 March 2023 at 01:16 #44810
Stoobie
GOLD MemberDoes anyone know (Keith Saunders especially) whether any B&O dealer that has access to the configuration tool, can access the original XML files on the system.
If the dealer that programmed the remote closes, can another dealer access the server and either change the current configuration or give you a copy of the XML file to save and work on yourself.
Thank you
Stoobie
19 March 2023 at 19:42 #44811 Keith Saunders
BRONZE MemberDoes anyone know (Keith Saunders especially) whether any B&O dealer that has access to the configuration tool, can access the original XML files on the system. If the dealer that programmed the remote closes, can another dealer access the server and either change the current configuration or give you a copy of the XML file to save and work on yourself. Thank you Stoobie
There is a central database for customer XML files.
When you use the Beo5/06 configuration tool there is the option to login to the dealers B&O account or not login. The configuration tool will still work if you are not logged in, but any XML files created will only be saved on their local PC.
Dealers were expected to be logged into their B&O retail account, but many did not do so.
If your dealer was logged into his B&O retail account when he/she created your configuration file, then another dealer would be able to download the configuration if that dealer had your Beo5/6 or its serial number.
In practical terms if you went to any B&O dealer with your Beo5/6 when he/she placed it on the base connected to his logged in configuration tool it would search the local PC and then the B&O server for the serial number. If it found it, then it would load it immediately.
Keith..
19 March 2023 at 20:02 #44812 Stoobie
GOLD MemberThank you Keith,
I thought might be the case. And I did wonder about dealers keeping local copies.
Stoobie
8 November 2023 at 02:26 #44813Tah_au
BRONZE MemberHey,
we have about 10 Beo 6 remotes, our service center that we used to program the remotes originally has closed down I believe the programing was uploaded to the data.
does anyone here have access to the data that could possibly download it for me, willing to pay for time.
Tim.
