Home › Forums › Product Discussion & Questions › BeoLit › Flacky Bluetooth connection between Mac and Beolit 20…
- This topic has 3 replies, 2 voices, and was last updated 6 months, 2 weeks ago by
matador.
29 August 2025 at 18:11 #69167
matadorModeratorI guys,
I’m currently in a home where, for my pleasure, I discovered there was a Beolit 20 available. First of all I honestly need to say that the sound is night and day compared to my Beolit 12 but no breaking news here I suppose. (Nevertheless, the 12 has Airplay and thats what I need…).
Well, I brought a Mac mini with all my music in it, remote controlled by my phone, etc etc…
It was a nice surprise to be able to declare the BL20 as sound output through bluetooth and enjoy the B&O sound.The problem is that as soon as the music stops (end of album, any pause or whatever…) when i want to resume “play” the BT connection becomes flacky, unreliable with cuts and drops. Then I need to declare another sound output from the mac and declare the BL20 back again and then it works well again.
Any idea?
Thank you.
29 August 2025 at 19:30 #69177Madskp
GOLD MemberMy best bet would be that another device is also connected to the Beolit 20 and has first priority to it.
This is based on my experience with my Beoplay Earset that is normally connected to my iPhone, but once in a while used with my Macbook. The stability of the connection to the Macbook is very random, whereas the connection to the phone is allways working.
Don’t know if it helps, but just my 2 cents
29 August 2025 at 20:44 #69178 matadorModeratorThank you Mads,
Make sense since it is a rented home.
I’ve reset the unit and it seems to work right now. But I will report on the long run as it seems to me to be a usefull intel.
This is Beoworld!
31 August 2025 at 17:38 #69254 matadorModeratorWell, no luck.
After multiple resets and pairing after unpairing the issue is still there: As soon as the music stop (end of an album), when the music resume the sound is chopped.
I then need to select another sound output and the Beolit 20 again to have continuous sound.(the issue may be on the Mac side since it sometimes ask me for a pincode to connect to the BL20).
