Home › Forums › Product Discussion & Questions › BeoVision › Eclipse/Harmony/Theatre audio via Beolink
- This topic has 22 replies, 5 voices, and was last updated 3 years, 5 months ago by
Sandyb.
5 November 2022 at 16:05 #39985
carolpaBRONZE MemberRegarding the Bang & Olufsen support (I asked for support), audio streaming of the TV program from the Beovision Harmony to Beosounds does not work! In reality, it works but unfortunately with a time lag = echo.
True, if you playing something on the LG, f.e. the Music app of LG and link to other B&0 devices.
But NOT true if you stream directly, f.e. DLNA sources or TuneIN, to the B&o Harmony using the B&o app. Then the sound will be in sync. (if the time delay on al devices are the same, as supposed).5 November 2022 at 16:48 #39986Alsfeld
BRONZE MemberTrue, if you playing something on the LG, f.e. the Music app of LG and link to other B&0 devices.
Yes, but for me (and others) THIS is a very interesting Use-Case and I do not understand why B&O is not supporting it better 🙁
I often listen to the news or any other spoken TV program (e.g. talk shows), you do not need to watch the display all the time because not much is happening. Parallel I like to walk around the house doing something and only listen to it. So it would be really great having no echo at all.
In the old days with Masterlink my use-case worked perfectly like a dream with Beovision 9 and some Beolab 35 around the house.
5 November 2022 at 17:41 #39987Sandyb
BRONZE MemberThanks – and that pretty much fits what my dealer told me, and what others have said.
So, the official line is that it doesn’t work, but we know it does but just not with proper sync’ing. And not an issue of environmental delay – its a shame, as it used to work well enough in the previous generation of BV’s.
