Home › Forums › Product Discussion & Questions › BeoLab › DIY Beolab 6000 Wood frets STL included
- This topic has 24 replies, 15 voices, and was last updated 3 months, 2 weeks ago by
Davy van Loon.
28 February 2024 at 04:23 #53103
cgh
BRONZE MemberIn the “DIY Beolab 8000 Wood frets (STLs included).” several people have been asking for frets for Beolab 6000 and I decided to give it a try.
Attached is the fret needed. 4 is needed for each speaker and they will fit nicely in the grooves for the normal cover.
The grooves are for 5mm wood, and there are 10 grooves i.e. 10 length of wood is needed plus two on the sides for each speaker.
The attached file has to be renamed to stl – it is not a pdf.
See below the fret mounted on the BL6000
You must be logged in to view attached files.1 March 2024 at 08:16 #53104cgh
BRONZE Member- I found that the fret when mounting at the Tweeter covers it partially. So I made a replacement fret for this one. See below before and after. Attached is the new fret in stl format. After downloading please remove the pdf in the end.
2 March 2024 at 15:15 #53105matiasjensen
BRONZE MemberHello Cgh,
Thank you for sharing files with us! 🙂
I’ll give it a try on mine BL6000 asap 🙂
BR Matias
6 March 2024 at 11:20 #53106matiasjensen
BRONZE MemberHi Claus
Is it possible for you to make clamps for beosound Stage?
6 March 2024 at 17:28 #53107cgh
BRONZE MemberAs I don’t have a beosound stage available for measuring I do not know what to construct.
Br cgh
8 March 2024 at 15:44 #53108MagnusMJ
BRONZE MemberHi cgh
Do you have the dimensions for the wood pieces needed for the project?
Length, width, thickness. For both middle and end piecees?
9 March 2024 at 21:51 #53109MVee
BRONZE MemberI am enjoying these initiatives to share .stl files for Beolab 6000 and 8000 upgrades. Thanks so much!
Some questions from my side:
- Does anybody have a finished pair, to see how this turns out with these clamps?
- Would you have an opportunity to create a 4mm wood option as well? Then they fit nicely with the Beolab 8000 variant that has 4mm frets.
- I came across a very nice version with 16 4mm frets and a tightly fitted clamp on the top. See the attached picture. Love how tight that fits. Would that give a nice option for the 6000?
- I have seen a wooden grill on a pair of Beolab 4000. Does anybody have the opportunity to create those as well?
Looking forward to your thoughts…
13 March 2024 at 18:41 #53110 JanBRONZE MemberDag,
I made something better I think.
Mayby not perfect.
Before I found this item I ordered some at Markplaats.nl for €50,00. See the picture below what he sent to me. Not so good. He said I have to use only 4 for 2 Beolab 6000-speakers. After complaining about it the answer was that the wil be good enough to use.
The original stl-files ditn’t work for me printing with a Dremel and Ultimaker original printer. There was a little gap between the things where you put the wooden frets in.
I dit turn it om 180 degrees before printing and printing the tweeter I had to use extra support.
I am working on the Beolab 2500 frets.14 March 2024 at 21:18 #53111 JanBRONZE MemberHello,
I’m no expert, but I was able to adjust both of your stl files with Tinkercad after printing. The small ridges where the wooden slats were located were loose because there was a gap between them and fell off or broke off.
See the photo, what the improvement is. On the left it’s your version and on the right it’s mine. What is not yet clear to me is whether 4 mm slats and a glue gun are needed or whether 5 mm slats fit between them.
Greetings, Jan
15 March 2024 at 23:26 #53112BramBoerema
BRONZE MemberHello,
How many of the tweeters you have top print for 1 speaker? Only 1 tweeter and 3 normal or?
16 March 2024 at 18:33 #53113 JanBRONZE MemberSomething is still not good enough.
The two bottem frets don’t fit and I have cut something off whit a sharp knife to make it fit. This maybe something to do with the fact I have mark 1 Beolabs 6000.So you need for one speaker:
- One on the top (STL is good)
- One for the tweeter (STL is good)
- Two for de bottem, witch I have to adjust. (Current STL using for the top is not yet good enough, but still can be used with a little adjustment)
I will try to adjust this in a new STL-file for the bottom.
18 March 2024 at 07:33 #53114BramBoerema
BRONZE MemberHello,
What are the things that have to be changed at the stl file?
19 March 2024 at 23:19 #53115 JanBRONZE MemberHello Bram,
Is it a idea to share your files for Beolab 6000 Mark 2 with us so that we can see what to adjust it for the bottom ones?
20 March 2024 at 07:45 #53116BramBoerema
BRONZE MemberHello,
I only have the files for the beolab 6000 that are given in this forum. I dont have files made at my own.
20 March 2024 at 07:47 #53117BramBoerema
BRONZE MemberMy message was a reply on the post of you.
28 March 2024 at 10:32 #53118sharknm
BRONZE MemberThank you for this. Mine are mark 1 as well and I will wait for the bottom one. I have a question, is there any chance to match it with 8000 frets, where the 4mm gap is used?
Thank you
28 May 2024 at 10:12 #56006marexy
SILVER MemberSorry, I do not see any STL file 🙁
11 June 2024 at 18:21 #56439c1sk0k1d
BRONZE MemberDear cgh,
I cannot locate the stl/pdf file.
Is there any way you could upload them again or indicate where to find them ?
Thank you !
15 June 2024 at 19:16 #56519TrebsT
BRONZE MemberAnybody got the files ? 🙂
12 July 2024 at 21:33 #57373cokeman
GOLD MemberI found the STL files for the Beolab 6000 wood covers, but they are impossible to download from the site. Getting error messages all the time. Any idea what the problem is?
