Home Forums General Discussion & Questions General Discussion & Questions Dismantling a Beosound essence remote / trying to fix it.
Viewing 6 posts - 1 through 6 (of 6 total)
  • #66108
    lechatsurletoit
    Hello,
    One of my Beosound essence remotes suffered from a battery leak and stopped working. The only solution I could find in order to clean it thoroughly and try to fix it, was to open it up, and since I could not find any proper documentation on this, I decided to post my findings.
    Disclaimer, I don’t know what Im doing, I probably suck at doing this, and there’s got to be a better way of doing it, I have nothing to lose, worst case I will use what is left as spare parts for the other remotes I have. this is post is only for futur referencing.
    1/Remove the cover plate / label whatever you want to call it. I used some pretty strong double sided tape and pulled way too hard, the whole assembly came off and broke 4 black plastic tabs that are screwed to the remote. Then I separated the black support from the cover plate with a razor blade, very very very gently.
    My B&O Icons: No description available No description availableNo description available No description available No description availableNo description available
    #66110
    lechatsurletoit
    2/Corrosion visible from the batteries leaking.
    #66112
    lechatsurletoit
    3/Plastic tabs remaining on the remote. Oh no! what have I done?
    #66114
    lechatsurletoit
    4/Drawing more power than it should (2.9v on a working remote).
    #66116
    lechatsurletoit
    5/Removing screws (Torx 2).
    6/Corrosion / oxydation wathever you want to call it.
    #66119
    lechatsurletoit
    7/Removing the back plate, IR LEDs will  bend straight when gently pulling it out, no other choice, clearly was not made to be taken apart.
    8/Cleaning with white vinegar and isopropyl alcohol (chatgpted this)
    9/Fixing the tabs back with superglue, seems to work
    10/Got some life back but still not working.
    I will bring it to a shop, but I believe I did the most difficult part.
