Home › Forums › General Discussion & Questions › General Discussion & Questions › Dismantling a Beosound essence remote / trying to fix it.
- This topic has 5 replies, 1 voice, and was last updated 9 months, 1 week ago by
lechatsurletoit.
2 June 2025 at 07:07 #66108
lechatsurletoit
BRONZE MemberHello,
One of my Beosound essence remotes suffered from a battery leak and stopped working. The only solution I could find in order to clean it thoroughly and try to fix it, was to open it up, and since I could not find any proper documentation on this, I decided to post my findings.
Disclaimer, I don’t know what Im doing, I probably suck at doing this, and there’s got to be a better way of doing it, I have nothing to lose, worst case I will use what is left as spare parts for the other remotes I have. this is post is only for futur referencing.
1/Remove the cover plate / label whatever you want to call it. I used some pretty strong double sided tape and pulled way too hard, the whole assembly came off and broke 4 black plastic tabs that are screwed to the remote. Then I separated the black support from the cover plate with a razor blade, very very very gently.
You must be logged in to view attached files.Location: Düsseldorf
2 June 2025 at 07:09 #66110lechatsurletoit
BRONZE Member2/Corrosion visible from the batteries leaking.
2 June 2025 at 07:10 #66112lechatsurletoit
BRONZE Member3/Plastic tabs remaining on the remote. Oh no! what have I done?
2 June 2025 at 07:11 #66114lechatsurletoit
BRONZE Member4/Drawing more power than it should (2.9v on a working remote).
2 June 2025 at 07:13 #66116lechatsurletoit
BRONZE Member5/Removing screws (Torx 2).
6/Corrosion / oxydation wathever you want to call it.
2 June 2025 at 07:17 #66119lechatsurletoit
BRONZE Member7/Removing the back plate, IR LEDs will bend straight when gently pulling it out, no other choice, clearly was not made to be taken apart.
8/Cleaning with white vinegar and isopropyl alcohol (chatgpted this)
9/Fixing the tabs back with superglue, seems to work
10/Got some life back but still not working.
I will bring it to a shop, but I believe I did the most difficult part.
