Home › Forums › General Discussion & Questions › General Discussion & Questions › Digital Power Link – What is it and what to do?
- This topic has 1 reply, 2 voices, and was last updated 2 years, 6 months ago by
Millemis.
6 August 2023 at 09:48 #48118
YannChrisGOLD MemberHello Beoworlders,
In a few weeks, BL50 will be delivered and I’m thinking about the best way to connect them to a Core that I already own.
I would like to have a direct digital path between the NAS hosting music files and the speakers, in order to avoid multiple DA/AD conversions and let the 50s do the job.
Looking at the specs, I noticed that Core has a DPL plug and that 2 DPL plugs are present on the Master BL50.
Could I use them to connect Core to the 50s (they would be connected to a Theatre through regular Power Link) ?
On another point, I noticed that Core is limited to 24 bits/95 Khz on it’s optical output. Is it the same for DPL ?
Thanks for your help,
Yann.
6 August 2023 at 09:55 #48119 MillemisBRONZE MemberThe DPL port does nothing – is for ‘future use’.
When or if this ‘future use’ will be available, is not known
Please also have a look here:The DPL port on the BL50 is for inter loudspeaker communication only.
As for digital inputs, apart from the USB audio input you have two SPDIF inputs – coax and toslink.
The optical input supports up to 24/96 – which is what the Core will output via optical.
