Home › Forums › Product Discussion & Questions › BeoVision › Deezer login on TV
- This topic has 2 replies, 2 voices, and was last updated 2 years ago by
mPartio.
7 February 2024 at 03:17 #52626
mPartioBRONZE MemberI’m finishing setup up on my BS4 based TV and cannot find where to setup my Deezer credentials.
When I was first setting it up I was sure I saw it pop up somewhere as I was checking out the various source options.
Now however it seems to have disappeared or is hiding somewhere.
Source setup doesn’t appear to have anything and the service menu doesn’t either.
When Deezer is selected it simply says “network connection not available” with no options for setup etc.
7 February 2024 at 23:19 #52627 MillemisBRONZE MemberYou probably mean the Deezer app in the SmartTV part of the Bsys4 (?)
As you may have noticed with the other apps there, this platform is obsolete….basicly no longer working.
In order to get Deezer to play on the BSys4, you will need an external device connected there with the Deezer app installed e.g. an AppleTV, a GoogleTV/Chromecast…….
Another way is to have a NetworkLinked B&O device in the setup, start playback of Deezer there and then Join in on the BSys4.
Using an Essence MK2 or the Core integrated with the BSys4 would even give you Deezer as a selectable source in the menu of the BSys4.MM
10 February 2024 at 15:42 #52628 mPartioBRONZE MemberThanks Millemissen for confirming. And yes I meant the internal app. I kind of wondered but really thought I saw it try to connect at one point when setting everything up. The Moment has no problem connecting to Deezer so I was optimistic it could still but, as you pointed out, it’s easy enough to link it to the Moment or one of the cores, etc.
