Home › Forums › Product Discussion & Questions › BeoVox › Dead BeoVox 100 woofer, but continuity trace OK?
- This topic has 4 replies, 4 voices, and was last updated 2 years, 11 months ago by
pl212.
6 April 2023 at 10:14 #45559
pl212SILVER MemberI have a pair of (recently refoamed) CX100’s, the left woofer of which is not outputting sound. No obvious failure state — the driver seems suspended evenly, well supported by the surround and not crashed into the side or otherwise damaged. A continuity traces shows a connection between the + and – terminal, so I think it can’t be a broken internal connection. (Swapping in the other woofer results in correct sound!)
Any ideas for troubleshooting a woofer in this state? Thanks!
7 April 2023 at 07:49 #45560 trackbeoBRONZE MemberI would measure the resistance of the good and the bad drivers to ensure they are approximately the same. Mere continuity could be anywhere between working and a dead short thru the coil or the wires rubbed against the frame, though you probably would have seen the latter. (N.B. Being a bear of very little brain, I hope someone else can suggest something more sophisticated.)
7 April 2023 at 08:15 #45561Dillen
ModeratorSure it’s not something else? A broken lead or a filter problem?
Have you tried swapping with the woofer from the other speaker?
Does it make a very tiny click-sound when you connect your ohmmeter across it?Martin
7 April 2023 at 18:33 #45562 Mark-sfBRONZE MemberI would check whether there is a short instead of a 4ohm measurement. You would need a multimeter.
23 April 2023 at 17:10 #45563 pl212SILVER MemberMany thanks for these ideas! Upon re-testing both the good and bad speakers, I discovered there is no continuity on the bad one (and thus obviously no ohm measurement.) The known-good woofer both shows continuity, and also reads out 5ohms.
Tracing a broken internal wire seems a bit easier than other problems, so I will start with that!
