Home › Forums › General Discussion & Questions › BeoWorld Feature / Problem › Current member status on this forum
- This topic has 1 reply, 2 voices, and was last updated 3 years, 11 months ago by
chartz.
10 April 2022 at 09:13 #34033
Keith SaundersBRONZE MemberAs most of you are aware Beoworld has four (4) member status’s and until we moved to the new forum these were reflected automatically from your account on the web site.
However, on this new forum everyone who registers currently gets a Bronze membership status unless I have manually changed it. I have been having some issues getting the permissions code working on the forum and some members status may change as I do further testing.
The bottom line is your membership status which appears under your avatar on this forum will not necessarily reflect your actual membership status. Your membership status will always be correctly shown on the web site and the membership portal
The final phase of the Beoworld upgrade will be when the current web site is updated and at that point the membership status will be back reflected correctly on the forum.
Thank you all for your continued support of Beoworld and the changes we are making which takes time.
13 April 2022 at 15:14 #34034 chartzBRONZE MemberHi Keith,
Thanks for that. Take your time.
