Home › Forums › Product Discussion & Questions › BeoSystem › (solved) Cover / Side removal of BeoSystem 3
- This topic has 0 replies, 1 voice, and was last updated 2 years, 9 months ago by
Blokkenpiloot.
Viewing 1 post (of 1 total)
20 June 2023 at 01:45 #47261
Blokkenpiloot
BRONZE MemberSOLVED: you can slide the panel up when removing the rubber feet!
How do i remove the side panel of the Beosystem 3, or is there another good way to glue the missing tab back on, so the side stays nice and flush to the device?
There is metal behind these tabs, because an magnet will stick to it, but i wasn’t able to pull out the tabs, maybe my magnet is not strong enough?
Thanks,
Aymeric Blok -
