Home › Forums › Product Discussion & Questions › BeoMaster › connection beosystem 2500 to Beomaster 6500
- This topic has 1 reply, 2 voices, and was last updated 5 months, 2 weeks ago by
Madskp.
28 October 2025 at 09:26 #70743
John Miles
BRONZE MemberHello
I am being offered a B&O Beosystem 2500 but without speakers. I would like to connect to my Beomaster 6500 in order to use the CD capacity of the 2500.
Bit not sure what type of connections are possible from the 2500.
Any clues.
Many thanks
John
28 October 2025 at 11:11 #70746Madskp
GOLD MemberIf you only will need the CD source from the 2500 you can connect the AUX on the 2500 to the CD input on the 6500. That way you can control both without disturbing double remote commands. But note that if you select radio or tape on the 6500 with a remote the 2500 will also respond to the commands, but since it is connected to the CD input on the 6500 you will not hear these sources.
