Home › Forums › Product Discussion & Questions › BeoMaster › Connecting Beomaster 5500 with Beolab 6002s
- This topic has 1 reply, 2 voices, and was last updated 1 year, 6 months ago by
Homersaurus.
2 July 2024 at 08:46 #57131
Aske
BRONZE MemberHi all,
I recently got ahold of some BeoLab 6002 speakers to hook up to my Beomaster 5500 (1989/1990 model). I’m running the Powerlink cables from one speaker through the other, so I only have one 7-pin DIN connector to the Beomaster.
From what I’ve understood so far, I need a DIN-to-Phono adapter, and then to connect the two Phono jacks to the ‘Pre-Amp’ output on the Beomaster. Can anyone confirm if this is the correct way? I’m still a novice, and really want to avoid blowing out my speakers!
3 September 2024 at 22:33 #58829Homersaurus
BRONZE MemberI would speak to Steve at Sounds Heavenly; he is very helpful regarding all sorts of connection cables. He can be contacted on this site or on the Sounds Heavenly website where cables for a variety of brands, including B&O, are available.
I can see your reasoning for a DIN to Phono adapter cable (as I have a 5500, but Beolab Pentas) – that type of cable is available from Steve. He may be able to advise a better method though, so it would be worth messaging him.
