Home › Forums › Product Discussion & Questions › BeoGram › Connecting Beogram RX2 to BeoMaster 1900
- This topic has 6 replies, 2 voices, and was last updated 2 years, 5 months ago by
BeoworldGarcia.
7 September 2023 at 01:55 #48674
BeoworldGarcia
BRONZE MemberI am trying to connect a Beogram RX2 to BeoMaster 1900 2904.
I just go these two items and I am not able to get sound from the turntable to the receiver.
The receiver seems to be working fine, when I plug in a Bluetooth device to the Tape input with a 5-DIN to RCA adapter plug I bought, I get beautiful sound.
The turntable seems fine, but when I plug the RCA jacks from the turntable to the same RCA jacks on the 5-DIN adapter in the Tape input, I get no sound.
I also tried the Phono 5-DIN input with the RCA adapter, and nothing.
Do I need a pre-amp? Or could something be wrong with the turntable?
Any help would be appreciated.
Thanks!
7 September 2023 at 06:04 #48675Dillen
ModeratorFor connecting to the Tape input you will need a RIAA.
The Phono input, however, should be at correct level – unless the internal RIAA in the
Beomaster has been disabled. It’s not that unusual to see. In that case, you should only
hear very low signal, and very treble-rich, because the RIAA correction is missing.Martin
7 September 2023 at 13:36 #48676BeoworldGarcia
BRONZE MemberOK thanks, going to try a pre-amp.
7 September 2023 at 22:31 #48677BeoworldGarcia
BRONZE MemberSo, I got a preamp, Pyle Phono Turntable Preamp, https://www.amazon.com/Pyle-Phono-Turntable-Preamp-Preamplifier/dp/B00025742A
Hooked up the RCA from the Beogram RX2 to the INPUTs, and sent the Outputs to the RCA to 5-DIN, into the Tape (also tried the Phono) inputs to the 1900.
I hear a very faint sound, some hum, but not working properly.
Any ideas?
Thanks!
8 September 2023 at 06:21 #48678Dillen
ModeratorBad pickup cartridge?
The faint sound you here – does it correspond to what you what expect to hear from the record?Martin
8 September 2023 at 18:26 #48679BeoworldGarcia
BRONZE MemberYeah the faint sound is the record, it is just one channel left, and some humm.
I am going to try a different pre-amp that says it is MM type compatible. Think that might help.
The guy that sold it to me swears it was working fine when he shipped it.
thanks.
10 September 2023 at 01:20 #48680BeoworldGarcia
BRONZE MemberThe new rep-amp is working much better. But right channel is not working, think it may be the cable.
So for B&O MMC2 you need an MM compatible pre-amp, like the one I bought:
And the reason I even need a pre-amp is probably because the BeoMater 1900 I have has screwed up Phono Inputs as was said above.
Thanks all.
